Exact Application of Valves
Please tell me the exact industrial application of following valves. For example gate valve, it is used to isolate equipment but for that purpose , we can also use globe valve or butterfly valve. Please explain me the exact application of each valve that in which condition we will use which valve? I have tried to find this on internet but not get specific answer
Gate valve
Globe valve
Needle valve
Butterfly Valve
Diaphragm valve
Gate valve
Globe valve
Needle valve
Butterfly Valve
Diaphragm valve
RE: Exact Application of Valves
Globe valve, needle and diaphragm valves can typically be used to control flow
Butterfly valve also used to control flow, typically in low pressure water systems
Needle valve more commonly seen in small bore in instrument usage
Diaphragm valve useful in dirty service or viscous fluids
Within each category there are many different variants so "the exact application of each valve " is not possible.
different fluids, pressures, flows could change the application.
http://www.wermac.org/sitemap/wermac.html
You should also check out this article"
http://pipingdesigners.com/contents/tips-tools-tra...
Sometimes its possible to do all the right things and still get bad results
