PreTension Load direction of a Bolt in ANSYS APDL
Dear Professionals,
I appreciate the response & comments. In the ANSYS APDL, the Clamp Force/Pre Load applied at the Pre Tension section of a Bolt represented by solids elements is shown by a Force labeled FX, not in the direction of Pre Load, i.e. along the Bolt axis, in the list, the magnitude of the force is clamp force applied. Why this force vector is not in the specified direction?
There are very high stresses at the pre tension section separation plane, is this usual in ANSYS? and can be ignored as Boundary Condition stresses.
Thank you very much for the help.
RE: PreTension Load direction of a Bolt in ANSYS APDL
Rick Fischer
Principal Engineer
Argonne National Laboratory
