How to tell if single outlet pipe's outlet end is submerged? - Detention Basins
In reviewing a detention basin with a single outlet structure being that of a 18" pipe with no riser attached, how do I analyze the pipe? I'm wanting to use this analysis to put together a table with elevations and discharges of the pipe. Would I analyze it using HY8 or using Orifice Equation?
Thanks!
BillsSis
Thanks!
BillsSis
RE: How to tell if single outlet pipe's outlet end is submerged? - Detention Basins
