Hollow concrete block wall
I have the task to design a hollow concrete block wall. The purpose of the wall is a partition wall. The wall will be installed over a concrete floor over ground. The owner of the building indicate verbally that the floor slab is 4” thickness and 3000 psi. The wall will be 10 feet height and will not be anchored on top. The client request the analysis to prevent construct new foundations for the new wall.
Comments request:
I calculate the shear capacity of the floor slab in 2√f’c bd in this case = 2√3000 * 12 * 4 = 5258 pounds per lineal foot (plf) vs weight of wall = 750 lbs plf then ok
How to calculate the seismic lateral reaction on the wall to calculate the anchoring to the floor?
Any other item that should be verify?
Seismic data:
Spectral response acceleration % of g
.2 sec 105
1 sec 34
Comments request:
Seismic data:
.2 sec 105
1 sec 34
RE: Hollow concrete block wall
You have two options: 1) New foundations, 2) Anchor the wall at the top.
Even the standard 5 PSF of interior wind load you should be designing for will likely induce more moment than that piddly little floor slab can take.
Lastly, something seems off on your shear capacity check. It's one way shear not two way remember. 5 k/ft just seems high in my eyes for a 4" slab.
That still doesn't solve your moment issues by not having the wall anchored at the top.
I can only anchor the wall at the bottom (over the concrete slab on ground). I'm thinking to anchor reinforcing steel #3 using Hilti Epoxy RE-500 with 2-3/8" min embedment. Gives approx 2000 pounds in tension.
*Revising the shear claculation based on comments.
.75 2√f’c bd in this case = .75 2√3000 * 12 * 2 = 1971.8 plf
The steel should be at the center of the slab.
If you anchor the wall to the slab w/ rebar, the cells need to be grouted. If the cells are grouted, your wall weight goes up.
Did you calculate the force in the #3 bar based on flexure of the cantilevered wall and compare this to the 2000 lb capacity of the bar? There are also reduction factors in Hilti's catalog that need to be applied that account for concrete thickness, edge distance, anchor spacing, etc.
Even if the slab shear is ok, the flexural capacity of the slab is probably not going to work if the slab is not reinforced. You may need to calculate the flexural capacity of a plain concrete slab (its not very large)
Listen to jayrod... he speaks the truth. What you've got here is a cantilevered retaining wall with wind/seismic load instead of dirt. Even if shear and moment miraculously work, there's no way that the joint between the wall and SOG works. Consider the joint design issues discussed in this thread and then imagine applying the same principles to a 4" SOG: Link.
.2 sec 105
1 sec 34
I will recommend new foundations however based on the IBC 2009 and the above seismic data how can I calculate the seismic resultant lateral force?
Then there's the matter of anchoring the vertical wall reinforcing at the floor when it's only 4" thick. What makes you think 2000 lbs. of tension capacity is sufficient to anchor a #3 bar? Besides, #3s are like spaghetti. I would never use #3s for vertical reinforcing. It will never wind up in the right place within the wall. I also question if your 2000 lb. calculation is correct. The realities of anchoring the proper reinforcing should kill the idea right there.
Finally, you have a 4" thick footing that you need to make work. Are there any nearby slab joints? You say "the steel should be at the center of the slab". How do you know that? If you're talking about WWR, it's useless anyway, especially at the center of the slab. You have a 4" thick plain concrete footing subjected to bending from both the vertical and lateral loading, and ACI 318 for plain concrete says you have to throw away 2" of that for concrete cast against soil... ridiculous! Don't let the client lead you around by the nose.
