Heat number in certificate list not the same with Heat number on mill cert.
Hi Everyone,
I was reviewing material certs for ASTM A105N carbon material and the certificate list contains a different heat number compared to the Mill cert. The Forging certificate and the forging trade mark remains the same.Do I accept this material as it seems the mill cert heat number is the starting heat no.Please does any one have an answer to this?
RE: Heat number in certificate list not the same with Heat number on mill cert.
Donad,
You appear to have placed your question in the wrong forum . I would suggest that you redflag this post and re -post it in the Metal and Metallurgy engineering Forum. forum 330
B.E.
You are judged not by what you know, but by what you can do.
