Convergence problems with ANSYS Workbench SOLID 65 finite element
Hello everyone,
I am modeling the debonding between concrete and CFRP subjected to tangential loading (single shear test mode II) using ANSYS Workbench, I used the contact element with CZM created in engineering data. now I have a convergence problem in the model. as you know with workbench you can't choose the element type. you have to insert commands for Solid65. When I use the SOLID 65 concrete finite element, my models lose convergence too early. If I remove cracking and crushing capability (Suppress the commands), there are no convergence problems. Why does this happen and how can I avoid it (I need cracking and crushing)?
I already tried the following to get my model to converge:
1- Refining the mech.
2- Reducing the normal stiffness of the contact region
3- Use newton Raphson residuals.
4- Playing with steps and sub-steps.
Any help or suggestions will be highly appreciated.
Thanks in advance.
RE: Convergence problems with ANSYS Workbench SOLID 65 finite element
Usually solid65 have bad convergence and requires appropriate data.
We tried to find optimal parameters for concrete and we presented our results here (in Russian)
http://cae-cube.ru/opredeleniye-optimalnykh-parame...
I hope it may help you especially if you use dictionaries =).
thank you very much "beastgod" for your reply, really appreciate it.
