How create controller tags between panelbuilder32 (using a pview 1000 stand) and compact logix PLC
Hello. I need to create or edit controller tags in panel builder 32 to link them wqith compact logix PLC, mi doubt is in the adress to use because compact logic desnt use numerical address, please help me how
RE: How create controller tags between panelbuilder32 (using a pview 1000 stand) and compact logix PLC
See if PanelBuilder 32 has an EtherNet/IP driver. If so use that, it should accept symbolic addressing.
