wave links not updating
I must have a setting messed up somewhere
Say I have a pin and wave link in a subtraction tool to the block the pin is mounted in
I then subtract out the linked body and I have my pocket
When I move that pin say .250in, the pocket is not moving with the pin
Even if I update all, and update external links, it still does not move
When I edit the linked body it highlights in the new position but doesn't move until I actually deselect the old subtraction pin and select the one in the moved position
Brian Marchand-owner
BRM Design
NX 10.0.3.5 / MP6
16G Ram - Nvidia Quadro K4000
Win 7 Pro x64
RE: wave links not updating
Have you tried fully loading all components?
-Dave
NX 9, Teamcenter 10
That's a good point, I can't remember if I had them all fully loaded or not---I will make sure and try again, thanks
BRM Design
NX 10.0.3.5 / MP6
Win 7 Pro x64
Arrangements and Move Component’s Arrangement = Use Component Prop/Apply to Used settings?
Michael Fernando (CSWE)
www.solidCADworks.com
Tool and Die Designer
Siemens NX V10.0 + PDW
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
No arrangements in this one Michael, gunman hit it, I just tried with fully loaded and worked no problem, I must have only had it partially loaded. It is a new install of NX10 so I wasn't sure---Thanks
BRM Design
NX 10.0.3.5 / MP6
Win 7 Pro x64
