Clear Cell Contents on VBA
Hi i'm new on vba and want to clear my inputs and autosave on one click.
i have tried this but have an inconsistent results (will clear on exit and sometimes retain its info.)
does anyone who's a vba expert that is willing to help :)
Private Sub Button1_Click()
Range("C18").ClearContents
Range("C21").ClearContents
Range("G6").ClearContents
Range("G7").ClearContents
Range("G8").ClearContents
Range("G22").ClearContents
MsgBox "Thank You"
Application.Quit
Application.DisplayAlerts = False
ActiveWorkbook.Close
If ThisWorkbook = False Then
ThisWorkbook = Save
End If
End Sub
MsgBox "Thank You"
Application.Quit
ThisWorkbook = Save
End If
End Sub
RE: Clear Cell Contents on VBA
CODE -->
Private Sub Button1_Click() Range("C18").ClearContents Range("C21").ClearContents Range("G6").ClearContents Range("G7").ClearContents Range("G8").ClearContents Range("G22").ClearContents MsgBox "Thank You" ThisWorkbook.Save Application.Quit End SubRE: Clear Cell Contents on VBA
i have another problem...
how to select cells to print? i am stuck with only 1 cell selected LOL :D
my code below
Private Sub commandbutton2_click()
Dim filename As String, lineText As String
Dim myrng As Range
filename = ThisWorkbook.Path & "\Results-" & Format(Now, "ddmmyy") & ".txt"
Open filename For Output As #1
Set myrng = Range("A17")
For i = 1 To myrng.Rows.Count
For j = 1 To myrng.Columns.Count
lineText = IIf(j = 1, "", lineText & ",") & myrng.Cells(i, j)
Next j
Print #1, lineText
Next i
Close #1
End Sub
i have tried to
Set myrng = Range(Cells(1, 4), Cells(12, 1))
i don't know why it only reads up to 12th row... type mismatch will occur if i go more than 12 rows.
and if you are too kind to share, is it possible to automatically open the csv/text file after this code? many thanks in advance...
Regarding your code above, I wonder if this part is correct:
This goes through the range D1:A12 - I suspect VBA will struggle with this shape of array.
To open files you use: Workbooks.Open - see here: https://msdn.microsoft.com/en-us/library/office/ff...
Skip,
Just traded in my OLD subtlety...
for a NUance!
