Chamfer or Fillet: It’s More Than a Coin Toss
FYI, we just posted an article on ENGINEERING.com based on a thread on Eng-Tips Forums. I hope you enjoy it.
Chamfer or Fillet: It's More Than a Coin Toss
Quote:
When and where to use chamfered or filleted edges is a question posed time and time again by design engineers and machinists.
RE: Chamfer or Fillet: It’s More Than a Coin Toss
Thanks Hailey.
I have some feedback I wanted to give: the intro section implies 'internal corners' per AJack's quote while the rest of the article applies mostly to external corners.
Might be good to try and clarify that point, perhaps tweak the sentence before the table:
"To try and shed some light on this question, <when looking at external edge breaks> the following are some basic factors to consider when making your machining decisions."
Or maybe change the 'title' above the table to
"Comparison Between Chamfer and Fillet <for External> Edges"
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Thanks for the feedback KENAT, a clarification has been made.
Good point KENAT.
internal chamfers or fillets are not the same. The internal fillet will normally reduce stress and not be a source of cracking, where this is not guaranteed for a chamfer.
An article on this would interest me a lot, but would probably be very complex.
Benta.
