NEMA MG1 Motor frequency variation during starting
NEMA MG1 is specifying a maximum 5% frequency variation during normal operation and also during starting:
"Medium motors shall start and accelerate to running speed a load which has a torque characteristic and
an inertia value not exceeding that listed in 12.54 with the voltage and frequency variations specified in
12.44.1.
The limiting values of voltage and frequency under which a motor will successfully start and accelerate to
running speed depend on the margin between the speed-torque curve of the motor at rated voltage and
frequency and the speed-torque curve of the load under starting conditions."
Is there defined anywhere the exact definition of what a variation is?
While trying to size a genset according to ISO 8528-5, usual manufacturer performance class G2 as in that standard, defines:
Transient frequency deviation from rated frequency during a sudden power increase <= -10%
I had a discussion with other colleagues whether the 5% frequency requirement during starting also applies for this requirement or not.
RE: NEMA MG1 Motor frequency variation during starting
You may get a lot more usable answer if you describe the intended application.
You may want to consider the interaction between a starting motor and a generator that is small enough that it is noticeably affected by motor starting.
Generally the first consideration of motor starting on a generator is not the effect on the motor, but the effect on other loads on the generator.
With the motor as the only load on a generator, a frequency drop when starting is beneficial to the motor.
As the starting load pulls down the generator speed, the UFRO feature will drop the voltage to maintain a safe V/Hz ratio.
This is similar to the action of a VFD when a low voltage and frequency is used to accelerate a motor with less heating than DOL starting.
A rue of thumb that has worked for me for numerous small generator applications starting residential air conditioners is a reserve of 3:1 times the motor size. (Usually based on the motor rated current.)
The voltage dip and frequency dip experienced by other loads has been acceptable.
For a generator starting one motor with no other loads, 2.5:1 has worked.
But, a large generator with a large base load will do better than a small generator and a small base load in comparison to the motor size.
Most generator manufacturers have software available online to size generators for motor starting loads.
Bill
"Why not the best?"
Jimmy Carter
Thank you waross.
This is an industrial plant with a large genset that not only feeds motors with direct online starting but also UPS/DC system and other static loads.
There is not a concern related to motor starting itself. It is a discussion with our engineering subcontractors that stick strictly to NEMA MG1 requirement of 5% max frequency variation for motors regardless of diesel genset manufacturer recommendation or sizing software or above all, diesel genset standard ISO 8528-5, which defines 4 performance classes (3 usual and 1 special to be agreed with genset manufacturer) and even for the most demanding class G3 (except G4 that is the to be be agreed with manufacturer), allows 7% transient frequency droop. Our engineering subcontractor insists in defining a more demanding requirement than that in order to fulfil NEMA MG1 requirement.
Sorry. Now I understand your question.
My take is that 12.44.1 applies to motor capability under stated conditions. It is not a requirement that those conditions be met.
Also I believe that 12.44.1 refers to sustained operation under the stated conditions, not transient conditions.
As I read NEMA 33.4.2.1.1. The performance of the prime mover, and by implication, the speed and frequency of a generator is outside the scope of NEMA standards.
As I read NEMA 33.4.2.5 under performance class G2 a generator is allowed a 24% voltage deviation during step loading.
I do not believe that NEMA 12.44.1 is intended to apply to transient conditions nor to generator capability.
That is one opinion. Wait for possible other opinions.
Bill
"Why not the best?"
Jimmy Carter
