Release Film
Release Film
Some years ago I used a film for release. I think the material was number D330. It was about .0035 inch thick, blue in color. I need to produce some material and I am almost out of the original release film. I have been unable to find a source and I’m not sure what to use as a substitute.
I am doing a wet layup on polished aluminum coated with PTFE. I placed the release film on top of the layup and used a top plate under pressure. The material is a heat cured epoxy at about 250 F.
Please excuse my ignorance, but could someone suggest a substitute material and a source?
RE: Release Film
B.E.
You are judged not by what you know, but by what you can do.
