Seawater Specific Heat
I'm looking for Reference Tables containing values for specific heat and density of seawater at different temperatures. Anything available on the internet?
RE: Seawater Specific Heat
In Perry 6° Ed. You have
TABLE 2-215 Sodium Chloride
Specific heat, cal/g °C
Mole %  6°C   20 C   33 C     57 C
0.249              0.99
0.99         0.96  0.97   0.97
2.44         0.91  0.915  0.915    0.923
9.09         0.805 0.81   0.81     0.82
and there is something similar for density.
You should determine before the concentration of sodium chloride (the main dissolved salt )
The CRC Handbook of Chemistry and Physics gives the following values for Cp in J/(kg.K) and density in g/cm^3 for a water of salinity S=35. S is roughly the mass of dissolved material in grams per kg of water.
 0C      3986.5    1.028106
10C      3986.3    1.026952
20C      3993.9    1.024763
30C      4000.7    1.021729
40C      4003.5
