Steel wide-flange column Damaged by Vehicle Impact
I wa asked to prepare a repair for a steel column that was dented by a vehicle. Damage does not look bad, but a repair is required based on the client. I would prefer to not heat treat and bend back into shape. i am considering welding a plate over the dented section. Still need to excavate down to the footing to ensure no damage at the connection. Would like to hear your thoughts on welding a plate vs heat treatment. Also how do the costs differ. See photo
RE: Steel wide-flange column Damaged by Vehicle Impact
As for damaged connections, if there is no damage to the slab there is most likely not damage to the connection. There would need to be visible distress or movement in the slab that would indicate horizontal or vertical movement of the connection
Link
Link
Mike McCann, PE, SE (WA)
