Level Indicator
Level Indicator
Please suggest best level indicator on storage tank
Application are Solvent + along with sticky material.
Solvent are methanol, Ethyl Acetate,SPDS.
Primary Purpose is avoid overflow of tank
RE: Level Indicator
A level indicator will not stop an overflow, you need some sort of interlock for that.
RE: Level Indicator
RE: Level Indicator
RE: Level Indicator
RE: Level Indicator
While I agree radar is a good choice for level I still prefer a bottom mounted DP cell for reliability perhaps with a backup level switch.
Cheers
Roy
RE: Level Indicator
a level indicator do not perform any action to stop the filling of the tank, the level indicator only shows the level of the tank in your control room (depending if it is in field or control room)
