Catia 2D drawing/drafting, weld symbol text information. (macro)
In a 2d view I have some weld symbolsn and i need to edit by scripting their textboxes but i can't find in the automation file how to do that.
There are 5 textfields for the weld symbols , 2 up, 2 below and another at the end of the symbol.
Does anyone know how can i acces those textfields and edit them automatically (catscript or vba).
Thank you in advance.
RE: Catia 2D drawing/drafting, weld symbol text information. (macro)
did you try to record a macro?
Eric N.
I tried but no action recorded during editing or creation of welding symbols. I saw that the macro recorder does not work all the time for all the functionalities....:(
CATIA isn't able to record in the drawing environment. I found out after searching to automate the threading info.
Use the DrawingWelding (Object).
CODE --> catvba
Dim drawingDocument1 As DrawingDocument
Set drawingDocument1 = CATIA.ActiveDocument
Dim drawingSheets1 As DrawingSheets
Set drawingSheets1 = drawingDocument1.Sheets
Dim drawingSheet1 As DrawingSheet
Set drawingSheet1 = drawingSheets1.Item("Sheet.1")
Dim drawingViews1 As DrawingViews
Set drawingViews1 = drawingSheet1.Views
Dim drawingView1 As DrawingView
Set drawingView1 = drawingViews1.Item("Main View")
Dim drawingWeldings1 As DrawingWeldings
Set drawingWeldings1 = drawingView1.Weldings
Dim drawingWelding1 As DrawingWelding
Set drawingWelding1 = drawingWeldings1.Item("CATIADrawingWelding0")
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
Hello drewmumaw and thank you,
O have managed to do it some weeks ago but i forgot to post here,
Here is how i did it if anyone else needs this:
CODE --> VBA
Dim textRange1 As DrawingTextRange
Dim textRange2 As DrawingTextRange
Dim textRange3 As DrawingTextRange
Dim textRange4 As DrawingTextRange
Dim textRange5 As DrawingTextRange
Set textRange1 = drawingWelding1.GetTextRange (catWeldingFieldOne)
Set textRange2 = drawingWelding1.GetTextRange (catWeldingFieldTwo)
Set textRange3 = drawingWelding1.GetTextRange (catWeldingFieldThree)
Set textRange4 = drawingWelding1.GetTextRange (catWeldingFieldFour)
Set textRange5 = drawingWelding1.GetTextRange (catWeldingFieldFive)
Dim char1 as String
Dim char2 as String
Dim char3 as String
Dim char4 as String
Dim char5 as String
char1 = textRange1.Text
char2 = textRange2.Text
char3 = textRange3.Text
char4 = textRange4.Text
char5 = textRange5.Text
'MsgBox char1 & " \ " & char2 & " \ " & char3 & " \ " & char4 & " \ " & char5
textRange1.Text = "xxx"
TextProperties.Update
