Constrain on tube
Constrain on tube
Constrain on tube
Hi All,
I'm doing some constrains in an assembly.(please see the movie)
I'd like to place the sheets against the outside of the tube in the middle. NX can't seem to make up his mind hot to keep them positioned. Like the green sheet. The for the contrain on the tube i use a mate relation sheet edge and tube outer face.
Is there some smart solution for this.
Lars
Lars
Solid Edge
Inventor
NX10.0.3.5 native
RE: Constrain on tube
If the result is not what you want, try using the "reverse last constraint" option before OK'ing the dialog.
www.nxjournaling.com
