Reading face details using VB macro
Hi!
I'm would like to read face details (i.e. face vector, and the origin for that vector). Despite many tyrings, I still don't have the solution.
My latest idea is to use the Face object as is thas the methods get:
Sub CATMain()
Set objSel = CATIA.ActiveDocument.Selection
objSel.Search ("Type=Face,all")
Dim SingleFace As Face
For i = 1 To objSel.Count
Dim oSel As objSel.Item(i)
'?????? What to do furhter??
Next
End Sub
Do you now how to read the data of the face/plane? The required data are stored in Plane object and are accessible through the methods GetFirstAxis and GetPosition.
Janusz
Sub CATMain()
Next
End Sub
Janusz
RE: Reading face details using VB macro
I am not sure exactly what you are looking for, but perhaps this can help you:
CODE --> vba
Sub CATMain() Set objSel = CATIA.ActiveDocument.selection objSel.Search ("Type=Face,all") Dim singleFace Dim axes1(2) Dim axes2(2) Dim origin(2) For i = 1 To objSel.Count Set singleFace = objSel.Item2(i).Value singleFace.GetFirstAxis axes1 singleFace.GetSecondAxis axes2 singleFace.GetOrigin origin Debug.Print "FirstAxis: " & Join(axes1, ",") Debug.Print "SecondAxis: " & Join(axes2, ",") Debug.Print "Origin: " & Join(origin, ",") Next End SubTesak
http://scripts4all.eu/txtoncurve/ - Text along a curve for Catia V5
Thanks!
Your tip exactly fulfills my needs.
The only problem is that it works when I have cuboid. When I have cylidner, for example, I receive the message "Object doesn't support this property or method".
Do you have any ideas how to cope with this?
Janusz
Tesak
