VB code to Select Note on a drawing using X and Y co-ordinates
I am looking for a help to create VB code in NX for selecting notes on a drawing sheet, If I know X and Y co-ordinates.
The code should select all notes under that rectangular area.
After that I want to delete those notes.
E.g. My point 1 is at ( x1,y1) and point 2 is at (x2, y2).
Then is should select all notes in rectangular area created by those 2 points and then delete.
RE: VB code to Select Note on a drawing using X and Y co-ordinates
This link shows some code that is very similar to what you want to do. Note that it only considers the annotation origin point when deciding if the note is in the rectangle or not. If you want to find notes that are completely contained within the specified rectangle, you will have to do some more processing.
www.nxjournaling.com
Thank you very much
