Abaqus Load deflection analysis in car door
Hello Guys,
I am doing an analysis in car door. The door has many critical locations so, i have to do load deflection analysis in all locations. Is there any option to do all location in single analysis? But the condition is 1 location results should not affect the other location. Please give me your suggestions..
RE: Abaqus Load deflection analysis in car door
If you are using linear Abaqus/Standard analysis you can use load case option.
See documentation: Abaqus Analysis User's Guide, 6.1.4 Multiple load case analysis
For any other case each load scenario must be separate model and separate analysis.
Bartosz
VIM filetype plugin for Abaqus
https://github.com/gradzikb/vim-abaqus
