import 3dPDF into NX
Is it possible to import/convert a 3D PDF into NX?
RE: import 3dPDF into NX
Can you export 3D PDF to some other format? stp, dxf, etc? I see no direct import of PDF in v8.5.3
g.
gbangs
TC 8.3.3
NX 8.5.3.3 MP11
I guess there is no an adequate way to export from 3D PDF to a neutral format.
Only tool that I think can convert 3D PDF is Tetra4D Converter: http://www.tetra4d.com/tetra-4d-converter/
This is the company that made the 3D PDF format.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (29versions)
Or if you have the discontinued Adobe Acrobat 3D and the PDF contains PRC B-Rep solid geometry you can export a STEP file.
