Switching Vs. Zener controlled supply
What are the pros an cons of a Switching mode power supply Vs. a zener controlled power supply (also known as emitter follower voltage regulator) ?
Everyone knows the first one. Here's a picture of the second one: http://www.radio-electronics.com/info/data/semicon...
RE: Switching Vs. Zener controlled supply
This is because the switching device is either on (low voltage drop, thus low power dissipation), or off (no current, thus low power dissipation).
In contrast, the linear regulator uses voltage drop over the transistor to control the output voltage. So high current and voltage drop at the same time, power dissipated as heat.
transistor gain or zener tolerance. They can easily be replaced by a single part of the
78XX type that are offered in a variety of voltages and currents. They can also be adjusted
to any voltage above the base voltage by the addition of two resistors. Low drop out varieties
also allow a smaller differential between input and output voltages. If going the zener route,
consider using a LM431 as a replacement for the zener. Last couple hundred I bought only cost
about 3 cents each.
Gunnar Englund
www.gke.org
