Arrangements
Arrangements
The last place I worked they did not use arrangements, but now I am using them for my own business and I like it. I have a question though. I have an assembly with a few clamps for example. I can go into my clamps and with my mates, create arrangement specific mates say for open and closed with a different angle for each. The problem I am seeing is when I want to open my clamps I have to go into each one and set the arrangement I want to use. Is there a way to set it at the top level so that when I show open, they all open. I know I could use explosion to show but I like the arrangements and I believe there is more to them then what I know
Brian
NX10.0.3 MP6
win 10
Brian
NX10.0.3 MP6
win 10
RE: Arrangements
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
RE: Arrangements
When I try and add a mate, without going into the sub assembly, it wants to move the whole sub assembly
If I try and move a component in the sub assembly from the top level, it makes the sub assembly work part first
RE: Arrangements
RE: Arrangements
www.nxjournaling.com
RE: Arrangements
Is the clamp assembly’s subcomponents set to Override Position state? RMB and select “Remove Position Override”.
If you have already created two Open and Close clamp arrangements, without using Override Position, use those arrangements at the higher level assembly arrangements.
Michael Fernando (CSWE)
www.solidCADworks.com
Tool and Die Designer
Siemens NX V10.0 + PDW
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
RE: Arrangements
The way cowski offers is the right way to do it.
RE: Arrangements
I will try the other method and see which one I like better, thanks
Brian Marchand-owner
BRM Design
NX 10.0.3.5 / MP6
16G Ram - Nvidia Quadro K4000
Win 7 Pro x64
RE: Arrangements
