Reflected Inertia of Slide Table Driven by Rack & Pinion
How do you calculate the reflected inertia for a slide table driven by a rack and pinion? Is it similar to a ball screw drive, replacing the lead of the ball screw with the pitch circumference of the pinion?
RE: Reflected Inertia of Slide Table Driven by Rack & Pinion
Wr^2
Jpinion = ------
2g
J = Inertia (lb-in-sec^2)
W = weight of pinion (lbs)
r = pinion radius (in.)
g = gravity (386 in/sec^2)
To calculate the Inertia of the load:
Wr^2
Jload = -------
g
W = weight of load (lbs)
Hope this is what your looking for.
Cameron Anderson - Sales & Applications Engineer
Aerotech, Inc. - www.aerotech.com
"Dedicated to the Science of Motion"
http://www.electromate.com/Motioneering%20Software%20Instruction%20Handbook.pdf
for more info
