Weld Efficiency & Casting Efficiency Factor - ASME VIII Div. 2 Part 5
I am currently looking at an F.E.A report that follows the methodology of ASME VIII Div. 2 part 5 to verify an ASME VIII Div. 1 accumulator vessel.
The report mentions two factors that I can't find the origin of;
Weld Efficiency Factor
Could someone please enlighten me to their origins and where they can be found in the code.
Is the casting efficiency factor as discussed in UG-24 in Div. 1?
Any help would be greatly appreciated!
RE: Weld Efficiency & Casting Efficiency Factor - ASME VIII Div. 2 Part 5
Neither is addressed in Part 5.
You are welcome to come to my paper presentation at next week's ASME PVP Conference where I will talk about weld joint efficiency factors and Part 5.
