Blocking in steel wire reels
The steel wire reels that are used to feed cold forging machines for bolt production, if are of small diameter , like 5 or 6 mm , produce a knod or block due to bad wire arrangement. Is there a new solution or idea that this would completely be avoided automatically ?
RE: Blocking in steel wire reels
