Draftsight crashes on startup
Hi!
I just installed Draftsight, it worked fine one time but now it crashes on startup.
I have laptop with Windows 7 and HD 4000 graphic card. I tried to delete the appdata/roaming/draftsight file but that didn't help.
What should i do next? Any suggestions?
Here is the crash report:
File Name : NONAME_0
File Path : C:/Program Files/Dassault Systemes/DraftSight/bin/NONAME_0.dwg
File Extension : dwg
File Version: R27 (2013) release [31]
File SavedByVersion: [0]
File Size : 0 MB
Was Active : False
History :
_DOCINIT
42
-1
0
-1
0
RE: Draftsight crashes on startup
Maybe check your compatibility settings. Maybe this version isn't compatible with Windows 7. 2016 SP2 has just been released. It supports Win 7, 8 & 10. Sylvia
Thanks!
I had 2016 SP1, i downloaded SP2 and installed it. Now everything seems to be just working fine.
EDIT: When i restarted the program started to crash again.
