Aspen+ Subroutine Missing
I have done a subroutine for a membrane simulation in Aspen+.
I compiled sucessfully and obtained an mem2.obj.
I created a shared librairy with asplink command.
I gathered all the file in one folder and defined it as my working directory.
Finally, I refer to the name DLOPT text file: Membrane_Loc_dll.opt in the run setting. When I run the simulation I have the following error messages:
Processing input specifications ...
STRUCTURE FOR COMPONENT CARBO-01 HAS NOT BEEN DEFINED.
PCES CANNOT USE GROUP-CONTRIBUTION METHODS TO ESTIMATE MISSING PROPERTIES
USE THE STRUCTURES PARAGRAPH TO DEFINE STRUCTURES OF THIS COMPONENT.
STRUCTURE FOR COMPONENT WATER HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT OXYGE-01 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT NITRO-01 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT CARBO-02 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT NITRI-01 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT SULFU-01 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT CALCI-01 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT CALCI-02 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT CARBO-03 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT HYDRO-01 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT SULFU-02 HAS NOT BEEN DEFINED.
STRUCTURE FOR COMPONENT ARGON HAS NOT BEEN DEFINED.
* WARNING IN PHYSICAL PROPERTY SYSTEM
PARAMETER PC/ELEMENT 1 (DATA SET 1)
UPPER BOUND VIOLATED FOR COMPONENT CARBO-03
VALUE = 0.22300E+09, UPPER BOUND = 0.10000E+09
PARAMETER DHVLWT/ELEMENT 1 (DATA SET 1)
UPPER BOUND VIOLATED FOR COMPONENT CALCI-02
VALUE = 0.22559E+10, UPPER BOUND = 0.60000E+09
PARAMETER DHVLWT/ELEMENT 5 (DATA SET 1)
VALUE = 3670.0 , UPPER BOUND = 1500.0
PARAMETER FREEZEPT/ELEMENT 1 (DATA SET 1)
VALUE = 4300.0 , UPPER BOUND = 4000.0
* WARNING IN THE "STREAM" PARAGRAPH WHICH BEGINS ON LINE 149
STREAM NAME: COAL
THE SUM OF ATTRIBUTED COMPONENT VALUES IS NOT 100.0 FOR
COMPONENT: COAL TYPE: PROXANAL
IN SUBSTREAM NCPSD OF STREAM COAL .
STREAM NAME: COAL
COMPONENT: COAL TYPE: ULTANAL
*** SEVERE ERROR
ERROR DURING DYNAMIC LINK OF USER ROUTINE(S) OR IN-LINE FORTRAN
PLEASE CHECK FILE _1300avb.ld FOR LINKER MESSAGES.
*** SEVERE ERROR
COULD NOT RESOLVE USER OR IN-LINE FORTRAN SUBROUTINE(S):
SUBROUTINE "MEM2" IS MISSING
*** SEVERE ERROR
PROGRAM TERMINATED DUE TO UNRESOLVED ROUTINES
I checked if my fortran compilator is well installed and linked to aspen+ (http://files.engineering.com/getfile.aspx?folder=0...).
If you any tips or suggestions, you are welcomed.
Thanks in advance.
STREAM NAME: COAL
STREAM NAME: COAL
*** SEVERE ERROR
*** SEVERE ERROR
*** SEVERE ERROR
Thanks in advance.
RE: Aspen+ Subroutine Missing
I have met the same errors. See my topic here.
and
For this kind of error these ways can help:
- try to delete and choose thermo method here
Properties => Methods => Selected Methods
- delete an choose all components here
Properties => Components => Selection
If it didn't help then the problem lies within thero method and you should find one ore set of methods to satisfy all components interactions. Try to find problem component(s) for this delete them one by one.
Hope this will help.
