Can we use load modifiers in this case?
I am checking wind uplift on a light gauge steel framing roof in Southern California. I am seeing ni the cold-formed design software an input for load modifiers, the documentation states:
"Some Building Codes allow loads to be modified for combinations including wind,
seismic or multiple transient loads. Previous versions of LGBEAMER used a simple ‘Wind or
Earthquake’ check box that, if checked, would cause all loads to be multiplied by 0.75 when
checking strength interactions. Newer building codes use a more complex set of rules for load
modification and have eliminated the simple 0.75 factor for load combinations containing wind or
earthquake forces. "
My question is, since this is a load combination for wind, am I allowed to use the 0.75 load modifier on top of the usual ASD load factors? Thanks.
RE: Can we use load modifiers in this case?
DaveAtkins
Is this a new design or are you load checking an existing construction, because that would also make an impact as to what's applicable as well.
I have never agreed with this line of thinking. If you are checking the capacity of an existing structure, you should check it using today's codes.
DaveAtkins
