69 kV KSO OCB Tripping and closing coil current
The Tripping and closing coil are feeded by the battery at 125 Vdc. Do you know how many amperes and how much times is needed to open and close the breaker?
I check the manual but didn't see the answer.
RE: 69 kV KSO OCB Tripping and closing coil current
CR
serial number 58135.
The mecanism is SD-19.
My question is for this specific breaker, but also for others of the same type because this question is often raised in battery calculation
Watch out for aging type U bushings on those old oil circuit breakers. They make for an explosive combination.
I wouldn't be surprised to see 20A through the trip cct. They're on the slow end for breakers. 3 cycles at least I would expect.
CR
