Duct Design Experts, How do I de
How do I determine if my circular duct design needs stiffening rings? And, if it does need them, how do I determine the correct member size for the stiffener?
After reading "The Structural Design of Air and Gas Ducts for Power Stations and Industrial Boiler Applications," I used their determination of D/t, distance between supports over the thickness of the duct, as less than 10 will produce minimal meridional stresses. From this I determined for my duct design I get a value of 3.9 for my largest span between supports. I am assuming that since this value is less than 10 that I will not need any stiffening rings. The pressure for this duct, in history, has reached a maximum of 15 in of H2O, ~0.5 psi. Since this pressure is minimal my hoop stresses are minimal. Is my method behind this correct or am I off in the wrong direction.
Also, the duct design it needs to be relatively modular for installation. How do I determine what member size I should use for my mating face? My duct size is 11'-6" OD and I was considering rolled channel but I do not know how to best determine the size. Along with the mating condition how do I determine the best choice for gasket material?
Thank you in advanced for all of your help,
CTmecheng
CTmecheng
RE: Duct Design Experts, How do I de
