Is it possible to create a section view using NXOpen ?
Hello Everyone,
I need to create a drawing section view using NXOpen API's in NX9.0 ?
Is there a way we can accomplish this as the API says "Not Implemented"
A sample code or snippet will be of great help. Thank you for your help.
Amitabh
Amitabh
RE: Is it possible to create a section view using NXOpen ?
www.nxjournaling.com
Have you tried recording a journal in interactive NX? The journal file will be horribly verbose, but it will probably contain the code you need.
