Floor drain and domestic washer????
Hello members,
I'm new in plumbing design and my question seem simple to alot of people but i really need help?
I'm designing a multi family apartment building and i'm wondering if it require by code to provide floor drain for domestic clothes washer? If not require is it good practise to have one? If so what is DFU i should count?
Thank you
Thank you
RE: Floor drain and domestic washer????
Second, where is your senior engineer? He should be providing guidance on these things.
Third, direct connection to sanitary sewer line is not permitted, but a "floor drain" is not required. The problem with a floor drain receiving clothes water drain is that it will splash and make a mess of the floor. Therefore a floor drain is not advisable.
Wash boxes don't come with the waste piping, trap or vent. They will have a hole in which the washer drain can be placed and the waste piping connected but that's it. From the box you will need a length of pipe before locating your trap, from that point you need to design the waste like you would for any other fixture. The next big question is how long to make the box's drain piece; I typically do 36" but you need to confer with your senior engineer who will be signing/sealing the drawings on his preference.
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
