Heat Dissipation Calculation for Water Heaters
Hi engineers.
Recently I was asked this question which I have no knowledge of. Hope to get some ideas and knowledge from here to start off.
For a commercial Hot Water Heater with storage tank type, is there a fixed formula to calculate what is the heat dissipation of the heater.
Figures given; 54kW, 480V/3P/60Hz, 65A. The tank is a stainless steel 500 liters capacity. There is 50mm thick rock-wool insulation and 0.4mm thick stainless steel 304 external cladding.
Thanks.
Thanks.
RE: Heat Dissipation Calculation for Water Heaters
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Or, what these losses contribute to the space the heater is in?
What the capacity of the heater is? (54kW)
If you're trying to figure out the standby losses you need the side surface area, bottom surface area, top surface area, and knowledge about pipes coming to and from the tank.
Perhaps you should tell us exactly why you're needing this 'result' as then we can help you more effectively.
Keith Cress
You could start here. You'll need to estimate the "R-Value" of the insulation. You'll obviously also need to know the water and ambient temperatures. There can be other losses, such as back through the cold water pipe.
For my domestic hot water heater, I bought a tank with "high tech" (high R-value) insulation, put it on a slab of blue insulation board, added an external blanket kit, plumbed the pipe with 'anti-siphon' bends. I was trying to minimize standby heat loss to save money.
Nevertheless, payback appears to be under a year.
TTFN
Dan - Owner
http://www.Hi-TecDesigns.com
That'd be 125 watts of heat loss. $165/year at $0.15/kwh. Sounds about right for a fairly well insulated installation. Because of the NPV of $165/year, it'd be pretty good ROI to make more investments towards reducing that further.
My next project would be a tempering line to naturally (free, at least in summer) raise the temperature of the very cold well water before it enters the HW tank. I expect that'll give the best ROI for a cheap project.
On the other hand, it is "double jeopardy during the AC season.
Insulation may be more cosy effective than timers.
Bill
"Why not the best?"
Jimmy Carter
Keith Cress
Yes.
Schedule timers in a heating context are funny...
Cutting power doesn't directly stop the thermal losses. It's the subsequent temperature drop (e.g. of the water) that reduces the temperature gradient (water to ambient), and that's what eventually reduces the heat loss. How fast that happens is a measure of how poor the insulation is.
In other words, if a timer saves you lots of money, then your insulation is inadequate. Conversely, if your insulation is really good, then a timer isn't going to save you much money (because the water temperature would hardly drop over eight hours). There might be a middle ground in between.
The conclusion is that a timer isn't a good thing. Certainly nothing to be proud of.
A 'timer' (controller) in the context of Time Of Use metering is different of course.
