Geopak Surfacing
Geopak Surfacing
Geopak Surfacing
I have been trying to interpolate between sections. When I do I get an error message "color mismatch" and when the surface comes in I have a warped and twisted surface. Any Ideas?
Also, I would like to add intersections. I have tried to copy the design into the 3-D file. Should I run a profile along the edges I want to layout in the 3-D file?
RE: Geopak Surfacing
It looks like you may have some elements that are the wrong color. Geopak uses level and symbology to distinguish between different element types (road surface, etc.)
My recommendation is to use the Edit>Select By Attributes function to find the rogue elements.
Good luck,
Robert Weber, EI
Maurer-Stutz, Inc
www.maurerstutzinc.com
"I am satisfied that your answer is correct. I am not, however, satisfied that your answer is right."
RAWeber,
Thanks for the tip. It seems to work. I will try that along with trying the power selector. That should do it.
Namdac
