Wind Load Effect on Closely Spaced Vertical Vessels
Is anyone aware of requirements in ASCE 7 to increase the wind load due to closely spaced vertical vessels (towers, stacks) of similar shape and height? I know other codes (international and some mechanical) do have a factor based on the C/C distance of the vessels but haven't found anything in ASCE that addresses this. Thanks.
RE: Wind Load Effect on Closely Spaced Vertical Vessels
