ACC conductor
ACC conductor
is it possible to use ACC conductor with 11/6.35KV with 33/19 KV system
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: ACC conductor
ACC is a signal cable supplied with end connectors and used to, among other things, trigger remote camera flash units.
ACCC and AAC are bare conductors and as such are not rated for voltage.
Some constraints are:
Rating of the existing insulators.
Spacing of the existing insulators.
Corona effect. Some references give 30 kV as the threshold for corona subject to other conditions. However, corona is rarely an issue at 33 kV.
Bill
"Why not the best?"
Jimmy Carter
