View Break - dimensions
Hello!
I try to get the dimension tags using NX Open that are connected to View. Problem appears when in drawing I use View Break.
Dimensions loose connection with base view after view break. Have you any idea how can I recognize this dimension tags?
Thank you!
RE: View Break - dimensions
Quote (PattP)
What problem are you having, the dimension isn't recognized? Is there an error returned? If so, what is the error message? Can you post the relevant section of your code?
Also, what version of NX are you using?
www.nxjournaling.com
