View>Update>Sheets instruction in CREO 5 drawings
I'm using CREO 5. Has anyone else noticed that Subject instruction doesn't work? My interpretation of the command is that it will update every view on every sheet, but I find that it doesn't work per my interpretation.
Can anybody correct my thinking or shed some light on the issue?
Bruce
Tunalover
RE: View>Update>Sheets instruction in CREO 5 drawings
Newest available release of Creo is 3.0 M100. You must be using Wildfire 5.
In Wildfire 4 it only updates the sheet you are on.
depends if you use the menu option (and which) or button.
dgallup:
The program I'm using is called Creo Elements/Pro 5.0. Is that not Creo 5?
Tunalover
No, it's one of the worst naming conflicts ever dreamed up by moronic marketers. When PTC had the bad idea of renaming their CAD suite from Pro/E to Creo, they took the existing Pro/E Wildfire 5 and slapped that stupid moniker on it without changing anything other than the startup splash screen.
