Coupling Seizure
Coupling Seizure
In our DCU plant, we have 2 nos of FD fans (identical) for supplying combustion air to the burners with the following data :
Flow : 10.896 m3/sec, Static pressure :4700 pa (479 MMWC), Rated power : 61.25 KW
Temp : 35C, RPM : 980, Motor rating : 75KW. Impeller type : Backward curved.
Each fan has a IGV at suction for flow control & discharge damper is full close or full open & has a full close command on individual motor trip. Heater has a trip on low combustion air pressure in individual ducts (4 passes) to the burners.(25MMWC trip pressure against a normal of 34MMWC in individual passes).
Fan-A has a inherent problem of coupling failure (more than 3 times, last one in Jun'16).It is a practice here to run both fans in parallel since its commissioning. Present flow is around 6.6 M3/sec & static pressure is 410 MMWC. This is done by throttling the IGVs of both the fans.(Control is single command for both IGVs) In all previous cases, the coupling bolts & shims break getting uncoupled with the motor but motor still running (doesn't trip), therefore doesn't closes the discharge damper & flow from Fan-B goes to Fan-A & reverse rotates the fan. (This is obvious & only a after effect of coupling seizure). Then, discharge damper of Fan-A is closed manually.
Another important fact is that normally after every start-up, one fan (Fan-B in last 3 cases) is started first as the flow requirement is less initially & after a certain time interval the 2nd fan (Fan-A in last 3 cases) is started and IGVs of both the fans are adjusted accordingly to get the desired flow & static pressure.
From above, it can be concluded the Fan-A starts against a back pressure (created by the static pressure of Fan-B). Is it because of this that the Fan-A never recovers under parallel operation, operates on the left of the peak pressure of the fan curve and goes under stall. Due to this flow reversal in fan-A, coupling shims & bolts breaks as they are weakest components in that line. Also, the stalling zone is not defined by the manufacturer in the individual fan curve.
Also, there is no vibration issues reported & so the factors such as misalignment, bend shaft, eccentricity, unbalance may be ruled out.
If above is the cause, how to know & confirm it.
We are finding it very difficult to access the parallel performance of the fans and have no idea how the combined curve would behave under the present operating conditions.
Any advice/suggestion to get a permanent solution to this problem.
Thanks in advance.
Thanks in advance.
RE: Coupling Seizure
Do the motors have electrical soft-start device?
Possible actions could include:
1) Verify discharge damper (actual) position prior to startup
2) Verify reverse rotation and shaft speed
3) Measure shaft torque transient (strain gage telemetry) and shaft speed during startup
4) Evaluate changing shaft coupling to a larger size or different type (elastomer or permanent magnet coupling)
5) Evaluate motor soft start device (electrical or permanent magnet shaft coupling)
Walt
too bad there aren't any pictures and drawings
.. yet
Sounds like this type of coupling.
http://www.ach.nu/media/attachments/rexnord-thomas...
The bolts break too?
The coupling manufacturer should be able to offer an opinion after seeing all the broken parts, and installation details.
There should be 2 separate shim packs
I would not count on vibration readings to discount misalignment or bent shafts or eccentric hubs.
I would watch the new coupling packs for puckering or bending when rotating the fan by hand,
Then repeat the inspection with a strobe light when the fan is first started.
Then repeat the inspection after each start of the second fan.
The use of the OEM curved or beveled faces washers is important for disc life. And they must be installed properly.
I'd discreetly check to see how they are being installed rather asking the millwright how they are doing it.
Here is a link with pictures of a few of the problems I mentioned.
http://heliwrench.blogspot.com/2008/10/inspection-...
Johnny Pellin
Reply of Strong's questions :
a) There is no soft starter. Motor is a 6 pole, 3 phase, 415V, 75KW,124 FLA, 980 rpm; Make - Crompton Greaves; Frame-E315M and starting mode - DOL, Motor Starting torgue : 200% of Full load torque. Also, Fans full load torque = 584 NM at full IGV opening.(as per OEM data)
b) As already mentioned, Fan-01 starts against the back pressure of Fan-02 (already running), starts against reverse rotation as discharge damper is fully opened before starting.
c) Motor speed cannot be taken now as both fans are running & no tachometer installed. (Any other method available ?)
d) Shaft torque transient (strain Gage telemetry) : What results can be achieved through this & how it will contribute in the failure analysis. (I have no knowledge in this part, kindly help me with some literature, source books & also, name of good parties who does this)
e) Coupling selection seems OK as required " HP/100 rpm rating" is 10.20 (HP/100 Rating = HP x 100 x SF/RPM = 100 x 100 x 1 / 980; service factor taken as 1 for fans / blowers as per coupling manual) as against the rated "HP/100 rpm rating" of the coupling is 25. Coupling make : Unique transmission, Series-80, size-250; manual available in net). Max bore size for this coupling model is 90mm.
Motor shaft dia = 80mm & pump shaft dia = 65mm at location of hubs.
Reply to Tmmose's questions :
Yes, coupling is a spacer type (drop down type) with 2 disc packs without any overload bushes.The shim pack & bolts of the DE completely found damaged. (Attached few photos available). Installation was correct I suppose.
Reply to Pellin's questions :
Fan arrangement attached in the drawing (not mirror image). One in the left side fails. Fans & Motors are completely identical (Fan Make is TLT & other details already given above). One correction : Impeller type is hollow airfoil.
Another observation made (not sure, please comment) :
On 04.07.2016 (post failure), both the fans were running & following are the parameters recorded from DCS :
Static pressure before APH (03PIC802) – 173.73 MMWC
Total flow (03FI802) – 23643 kg/hr.
IGV opening on both fans : 40.46% (Auto Mode)
Current reading: 75A on each fan motor (in local ammeters)
From the current reading of 75A, motor output power (fan BKW) of each fan is coming as 42.39 KW (approx) considering a power factor of 0.85 & motor efficiency of 92.5% from data sheet. If we plot this in the individual power vs capacity curve for individual fans (as given by mnfg), we see that each fan should give flow of around 6.3 m3/sec ie 23616 m3/hr volumetric flow. Considering air density as 1.07 kg/m3, mass flow of each fan is coming as 24267 kg/hr. Since IGV opening is same at 40.46% on both the fans, ideally loads on both the fans should be equal & the total mass flow should be 24267 x 2 = 48535 kg/hr. But as per DCS figures, total flow is showing as 23643 kg/hr. This signifies that we are not getting a mass flow what is approximately expected or in other words, one fan is overpowering the other fan. (Why this is happening probably because Fan-01 starts against back pressure of Fan-02 which is already running!!!)
for further advice & inputs,please
Bhaskar
"Fan-01 starts against the back pressure of Fan-02 (already running), starts against reverse rotation as discharge damper is fully opened before starting."
If this is the case, I would expect the possibility of coupling problems. It is never a good practice to start a machine that is already spinning in reverse. It would be better to start the fan with the damper closed and risk a short duration surge. Adding a ratcheting, anti-reverse mechanism would give you the best of both worlds and allow start-up with the damper open but the fan not reverse spinning. But, those mechanisms can be prone to problems. We only use those on our deep water wells and they have caused some failures.
Johnny Pellin
Capturing the starting surge peak amps will tell a different tale I believe, just as the reported coupling failures indicate.
Starting a heavy or large diameter fan across the lines is pretty strenuous.
Starting one that is spinning backwards requires FIRST stopping it, then a strenuous start.
At some point the motor shaft and the fan shaft may also object, and provide broken parts with fracture surfaces that match the text book examples of low cycle fatigue, starting from stress concentrating details like key seats, shoulders, threads, thread relief grooves.
Fan 1 starts against reverse rotation.
Well there you go.
Measure torque to prove that coupling is undersized for startup transient, because of starting against reverse rotation.
Start Fan-A with discharge damper closed, and then open it when fan reaches full speed. There is generally no harm to fan for short operating time with damper closed. This should be cheaper that starting again reverse rotation.
A FluxDrive SmartCoupling (www.fluxdrive.com) can provide a mechanically soft-start even with reverse shaft rotation.
Walt
Does the duct expand after the second fan inlet?
Why not at fan 2 inlet?
What is velocity pressure of desired fan A flow?
Can it overcome static at fan B?
My random thought is to install an inlet box on fan B and run fan A into fan B by shifting fan A outlet inline with inlet box on fan B, but I have no idea if the fan curve(s) get you to the operating point you want with fans in series.
Maybe install a fluid coupling.
We have already started thinking in the line of starting the motor by keeping damper closed & once speed reaches its full, we will be opening the damper full. (For this, we will have to reverse the interlock; that is OK). This will hopefully ensure starting & gaining its full speed without any back pressure from the other fan.
As far as measuring the fan speed is concerned, we have got tachometer but we have to install the reflective tape and for that we will have to stop one fan (that is not possible as of now). Piece of cardboard concept is also a nice tip. thanks strong.
Strong has mentioned this point "Measure torque to prove that coupling is undersized for startup transient, because of starting against reverse rotation."
This is not possible as of now as current trend is not available. But assuming that the measured torque is more than the required during start-up period (causing torque transients during start-up), will that carry forward in the steady state (ie once motor reaches its full rpm). ie. torque reversals happening in steady state. If that is true, then my above calculations appears correct ie one fan overpowering the other fan & causing flow reversals/therefore, torque transients.
On contrary to it, the current is showing steady at 75A (as of now in both fans running). Fan BKW comes at around 42.39 KW. Torque at this power comes as 413.03 Nm @980rpm.
My questions now are :
1) Even if flow reversals / torque reversals are taking place (just assuming), will it have no effect on current ie current fluctuations ?? But current is steady. (or considering big mass of the impeller-motor system, there will be no effect)
2) Since start-up current trend & therefore, start-up torque transients (during start-up) is not available but assuming flow reversals going on in Fan-01 at present (with flow calculations as shown), then how to ascertain torque reversals at this moment (2 fans running steady at 75A each). And from that how to ascertain that the coupling is undersized to handle torque reversals. (Note : rated torque of this coupling - 1780Nm & Peak Torque-3560Nm).
Also, checked the fluid drive smart coupling. This is a fantastic breakthrough !!thanks Strong!!. Will axial thrust have a effect in this type of coupling (although 1 fan bearing is fixed). Fluid coupling is also a good advice by dvd. Which one is having more buyback period??
I think I am getting nearer to the solution & hopefully will find the root cause.
Waiting for your kind comments & advice further,pl.
- The initial electromagnetic accelerating torque during reverse rotation won't differ significantly from locked rotor torque (torque during start from standstill).
- The torque seen at the coupling during start in absense of torsional oscillations is
- _____Tcoupling = Telectromagnetic * Jfan/(Jfan + Jmotor) (neglecting role of Tfan)
- I don’t' see that the potential for torsional oscillations is significantly affected by reverse rotation.
- The torque we talk about during starting represents an average over one or more power cycles… there is actually a large superimposed ac component of torque varying at line-frequency which tends to result from the dc offset in stator currents after start. I don't see a significant change in this.
- The only change I see is the time it will take to accelerate. So the coupling may be exposed to the same large starting torques including oscillating torque for longer a period when started during reverse rotation, but it's not obvious to me that it would see a higher peak torque.
- I don't rule out that reverse rotation plays a role in coupling failure (as supported by the fact that the motor started this way breaks coupling) but the cause->effect explanation from reverse rotation to broken coupling would not be obvious to me. I'm not arguing, but interested if someone can explain better about the mechanism by which starting during reverse rotation would cause a broken coupling and whether this is a known/expected phenomenon.
Wouldn't a severe stall condition show up in vibration? I know rotating stall often shows up at 1/3x or harmonics ofr 1/3 rotationg speed. Also we might expect some broadband noise floor in vibration and possibly audible noise I'd think. You have ideal situation of two identical fans to compare against each other. If there is no significant difference between these two machines in terms of vibration patterns and noise, I would doubt the scenario that one is carrying full load and one is stalling.Do you have a strobe light? If you are suspecting some torsional phenomenon you might get lucky and be able to see it when strobing the coupling and shaft at each end. Also if the coupling is Thomas/Rexnord shim pack then strobing the shim packs could potentially reveal some clues. While you're at it you can nail down the speed of the two machines for comparison.
I would think that most scenarios that result in varying coupling torque result in varying motor current. Do you happen to have pump curves including bhp vs flow. I am curious if it is a relatively flat curve. It seems odd that a motor you suspect as stalling would draw same current as motor you suspect is carrying the full load (is that what you said is happening?)
(2B)+(2B)' ?
Due to this flow reversals, torque transients might be taking place.
But will there be any current change/ fluctuations for these torque reversals? How to prove the coupling is underdesigned for this torque transient (if occurring).
Already raised these questions above against strong's earlier suggestion.
The blades are backward hollow airfoil type and fan curve is rising type. Stalling zone is not given by fan OEM. But flow shows at around 6m3/sec @75a in the curve for a single fan against a rated of 10.9 m3/sec. Stall zone will again increase for parallel fan operation.
Because the flex element (the shim pack) is readily visible, this particular type of coupling sometimes gives clues as to the stresses it is seeing or has seen. So there is potentially a wealth of information available by carefully inspecting the coupling any of these times:
1 - during operation (*)
2 - during routine shutdown
3 - following failure
* inspecting during operation is obviously the trickiest. If you are lucky enough to have good line of site and room for a strobe then try that. But often you may be limited to looking up under the small gap at bottom of coupling guard and there's just not enough room for eyeballs and strobe under there. In that case you can try sliding a camera under there and try to get a few flash photos. Under the right conditions flash photography effectively freezes rotating components. It stands to reason it works best when the area is otherwise dark under the coupling guard and you have fast shutter speed and slow shaft rotation. I've frozen a 3600rpm coupling with my old style cameras... haven't tried it with a smartphone yet.
Here is a document devoted entiely to inspecting this type of coupling for clues about stresses during shutdown
http://www.rexnord.com/ContentItems/TechLibrary/Do...
For the case of torque overload, see figure 10. When you visualize the path of torque transmission through the coupling, you'll realize that it places a given shim pack in tension over some arcs and in compression over alternating arcs. The boundary between these arcs occurs at the bolts or bolt pairs. If you overload the coupling, the strain grows in each region and buckling begins in the region of compression. It is depicted here in shutdown condition... would only be visible if the condition was severe enough to cause the shim pack deformation to remain after stress removed. During operation with full torque (or torque overload) applied, it should be more readily visible (if you have a clear line of site and strobe).
If you have axial force transmitted by coupling, it will show in shape of disk packs. Signs of misalignment might be seen. And there's more in that document. Almost anything that will cause the disk pack to fail would likely be evident at some point during coupling inspection. And having a sister machine coupling also available for inspection is just begging you to make the comparison between them.
Side note - at our plant we've found ejected pieces of shim sitting under the coupling guard (that's a big of a warning sign!). It starts as the cracking depicted in figure 8, but when you get two cracks there is potential for a portion to get flung out, especially if it is an outer disk in the pack (that doesn't have friction on each side holding it in).
There is some logic to starting where any good detective would start.... which is at the scene of the crime! i.e. try to study the coupling itself carefully to draw clues from there, rather than starting with more remote observations and trying to tie them back to the coupling with various theories. That's just a thought...I realize that's not always practical and I can also understand why you want to pull the string to understand why the flows don't seem right.
your question about current oscillationl... I still think current will oscillate in any scenario of oscillating coupling torque. I'll see if I can dig up some more relevant info or thoughts.
(2B)+(2B)' ?
I have seen some patterns (after taking photos as suggested) similar to fig no.10 of your upload.
Seems that the coupling is going through torque overload as per the depicted analysis. Does this also mean that torque reversals are taking place, then source of torque reversals must be the flow reversals. But the current is steady; this is diluting our confirmation of torque reversals. (RPM measurement would be fantastic but that is not possible now). Or current would be steady assuming that the magnitude of torque reversals is less (since it runs for substantial amount of time & then fails) than the magnitude of coupling torque rating (1750Nm)& may be the coupling is not design for torque reversals although it may be within the rated coupling torgue.
But how to prove this point practically at this moment.
Pl advice.
Did you have a chance to compare between machines? I'd be cautious about looking at only one...It's tougher to judge what is normal.
Still a little skeptical about torque reversals without current oscillation.
(2B)+(2B)' ?
failed fan coupling has a bowed or bulged out shim pack but the other fan is OK (Shim pack clamped together without any bow/bulging). Will soon share the photos.
The main evidence you are seeing to support a theory of flow or torque oscillation/reversal I think is the mismatch between predicted and actual total flow? (along with theory that it's related to coupling failures based on starting seqeuenc). Is there any other evidence of flow or torque oscillation/reversal?
The scenario further you suggest is pump B carrying full flow and pump A carrying low flow due to stall. I was trying to visualize that from curves where identical fans can carry different flows at the same dp. It seems more likely for forward curved blade (with hump in the curve) than for backward curved based on the qualitative curve shapes posted here
http://lh5.ggpht.com/_1wtadqGaaPs/TGrQc7fTvcI/AAAA...
From that curve also I assume power is bhp (vs fluid hp) and would expect different BHP at the two operating points and therefore different motor currents. But you reported same current on both fans. Maybe for some machine it would be possible to operate at two vastly different operating points with exact same current but that would seem to be a lucky coincidence. The simpler and less coincidental interpretation of the currents would of course be that the two fans are sharing load equally (although that doesn't explain why coupling A is bulging more, unless it was permanently deformed from prior overload or maybe was assembled improperly with fewer shims)
Compare the vibration patterns (and also listen). If one is stalling I'd expect some difference in pattern. IF on the other hand you find no difference in vibration pattern or noise, then based on that info (along with previouisly reported facts that there is no difference in the two current magnitudes and no current oscillation) then maybe start looking for other explanations.
(2B)+(2B)' ?
I can't accept most of your comments about effect of reverse rotation not affecting startup torque. I guess all of the anti-reverse rotation devices for fans and pumps should not be needed, if your comments were correct; or am I misinterpreting them? The peak torque transient depends on inrush current (electrical force) and the resistance to motion (inertia) of the motor and fan rotors. Reverse rotation (free-wheeling) of the fan adds more inertia, since the rotor must be decelerated before being accelerated in the correct direction. In addition to excessive peak starting torque, the coupling may see excessive torque during acceleration to full speed when passing through a torsional resonance. A torsional resonance at full speed can go undetected by relying solely on motor current measurement. I still say that reverse rotation, if occurring, is most likely cause of coupling torque overload during startup torque transient.
Walt
Reverse rotation causes a variety of problems. It takes the motor longer to get up to speed, drawing higher current the whole time which challenges the motor more and can lead to motor trip on thermal protection. I’ve heard it can unscrew certain impellers although I never understood that part. Reverse rotation with deenergized motor can in theory overspped the machine. There are a lot of things the device can do. Existence of reverse rotation device doesn't prove it's intended to prevent couplinlg failure.
Inertia depends on mass and geometry, it does not change. I can’t make much sense of your point.
Let me show you my way of thinking about it. Here my quasi-static analysis of starting. Consider it as a 2dof system:
Jmotor ==> Kcoupling ==> Jfan
Where J is rotating inertia, Kcoupling is coupling torsional spring constant.
Tmotor is em torque applied to motor
Tfan is fluid torque resulting from interaction with the fluid
Tcoupling is torque transmitted through the coupling
W = rotational speed in radians per second
quasi-static assumption: It includes two simplifying assumptions: 1- the entire train rotates at uniform w (neglects oscillatory behavior such as torsional resonance); 2 - assumes motor torque is a pure function of speed – neglects obscure oscillatory electric torque associated with dc component during motor start.
Acceleration equation at motor inertia and at fan inertia:
dw/dt = (Tmotor-Tcoupling)/Jmotor = (Tcoupling-Tfan)/Jfan
Solve Tcoupling = (Tmotor*Jfan+Tfan*Jmotor)/(Jfan+Jmotor)
where
Tmotor is electromagnetic torque. Under this quasistatic assumption it is the one given by the torque speed curve. We extrapolate it past the zero speed axis… most likely it is lower than locked rotor torque during reverse rotation.
Tfan is opposite polarity of Tmotor and so Tfan only serves to reduce the peak torque in the coupling during start when Tmotor>Tfan.
This quasistatic analsysis does not suggest any increase in peak torque from reverse rotation.
I previously tried to consider the limitations of the two quasistatic assumptions listed above, in the following bullets:
These last two bullets are open to discussion…. the trickiest part of the analysis imo (the earlier part was easy).
Yes. But no obvious difference for the start from reverse rotation or from standstill. If we look at speed vs time of motor accelerating from reverse rotation considering only the portion after it passes through zero speed, it looks identical as speed vs time curve of motor starting from rest. Both motor pass through any torsional resonance at the same rate. The only difference is some resonance the reverse rotating motor may have passed through before it got to zero speed and I have no reason to suspect such torsional resonance would be any worse than the torsional resonance between zero and full speed.
I agree. I don’t see that full speed torsional resonance has much to do with reverse rotation though.
LATE EDIT - I see now you are on a different point - you are suggesting there can be operating torsional oscillations placing stress on coupling without causing current oscillation? I'm not sure about that, have you seen it?
I don’t rule it out. But I haven’t seen a compelling argument that this is expected in general during a start from reverse rotation.
(2B)+(2B)' ?
Hold it against the motor or fan housing and watch the vibrating reeds.
The other thing that happens with starting in reverse rotation is that the higher momentum of the fan requires max torque for a much longer time and it also causes more shaft wind-up and deflection. I have seen shafts twisted, bearings damaged, and couplings destroy from this. And this was in systems where each part had been tested to >2x locked motor torque.
I would start against a closed damper and then open once the fan pressure exceeded the existing system pressure.
In simple terms, what I could understand is that as per strong's view, coupling failure might be due to torque transients during startup against reverse rotation and torsional oscillations at full speed not detectable through current measurements(current is steady at full speed). In contrary to that, as per EC's view, torsional ossilations are not affected by reverse rotation during start up and for torque reversals to happen at full speed (load), current should also vary, but in actual current is steady.
Here I would like to bring one point to your focus that the coupling is failing only after running a substantial period of time (min 4 months)after startup, this potentially signifies that something cyclic is happening (motor and load against each other) and eventually, coupling is the pray.
But if strong's point is correct, then strong may comment what other things we should consider/check (apart from current)at this stage to confirm occurrence of torque reversals or any possible reasons why torsional oscillation may not get detected through current at full speed (load). Possibly, please also think from the fan behaviour point of view under parallel operation.
I believe that the underlying assumption that most of us are making is that if the coupling material or alignment is damaged during startup then you will greatly shorten its running life. As much as we would like these couplings see significant load and stress when running, if they didn't we wouldn't need them we would hard couple machines.
(2B)+(2B)' ?
je suis charlie
http://www.monarchinstrument.com/product.php?ID=32
A strobe tach would -
1 - allow measuring the reverse rotation rpm
AND
2 - allow checking the coupling condition right after each start up
AND
3 - significantly boost your rep as a cool dancer
https://www.youtube.com/watch?v=me7Vr6Tzxa4
I'd like to see some pictures of the bolts that failed in both side view and full on the fracture face, particularly as this is a cyclic failure.
What's not been mentioned as yet is how the coupling is replaced in terms of methodology for example:-
How often is the coupling inspected?
When tightening a new coupling, do you use a torque wrench and follow a star like pattern whilst tightening the nuts?
Now these failures may well be caused by the working torque however a bolt which is incorrectly tightened could quite
easily contribute or even be the root cause of these failures.
So from my point of view, I'd start with my maintenance procedures as these should be fairly easy to check.
desertfox
I have seen where the "alignment" taken with laser tool showed good, But a straigh edge and latter dial indicator showed it out over 0.2"
One real possibility is one or both coupling hubs were not bored concentric to the OD.
The laser setups I used worked strictly off the shaft centerlines, with no real good method to even check for shaft straightness or hub eccentricity.
The only reasons drive bolts break on a disc coupling is because of severe over torque, or bolt fretting from loss of clamping force on the joint. Misalignment will not cause a bolt failure, that will cause disc pack failures. Sounds like you have a rotating inertia to overcome, that could cause the motor starting torque to spike at start up. I generally don't recommend over sizing the coupling unless that is truly the weakest point. So this may be an easy fix if the coupling has a very low service factor like 1.25 or 1.5. Then just go to the next size up coupling. However, most of the time that is not a good idea, that will just transfer your problem to another area, like instead of breaking drive bolts you will be breaking drive shafts.
And the easiest way to measure total misalignment is to measure the gap between the center spool and the hub flange. Take this measure measurement all the way around the coupling, the total difference between the largest and smallest dimension will give you your total pack misalignment by doing some simple trigonometry. Tan^-1[(Total difference/2)/(Coupling Disc BCD/2)] = Angle per pack misalignment. That value will sum all parallel and angular misalignment into one value.
www.psccouplings.com
When it comes to couplings we are always here to help.
WWW.PSCCOUPLINGS.COM
