Combo Solenoid Valve w/ Timer Recommendation?
For water pressure ranging between 80 and 150PSI in a 1/2 inch pipe with little to no back pressure,
looking for recommendations for a solenoid valve with an adjustable timer that can be user specified
to open for 1 to 5 seconds and then close for 1 to 5 minutes, repeatedly 24/7. Water and ambient are
both at room temperatures. Reliability is top priority.
Thanks for any suggestions!
RE: Combo Solenoid Valve w/ Timer Recommendation?
These timer operated SVs' are commonly used in air compression packages for dumping water from after coolers, separators and the like - ask an air compressor package supplier.
Thanks, georgeverghese, much appreciated!
