Boundary Steel In Shear Walls
We have a concrete shear wall with vertical concentrated steel at the ends (something like boundary elements). My question is related to the spacing requirements for ties in these elements.
I was told that ties for these elements would only be required if:
1) The reinforcement is required for compression
- or -
2) The reinforcement ratio is greater than 1%.
(per ACI Chapter 14)
I was also told that if the ties are required by either of the above provisions, there is no code-prescribed spacing limitation (IE you wouldn't need to meet the detailing requirements of ACI 318-08 7.10.5) . So in this example, even if we have a 10" wide wall the ties could be spaced 12" OC.
I'm not sure I buy this however. Section 10.10.3.6 implies that if you include your compression steel in a wall, even if it is less than 1%, you need to provide code-minimum ties.
To simplify my questions:
If I have a compression member integral with a wall with greater than 1% steel, do my ties have to meet 7.10.5?
If my steel is only required for tension, but is greater than 1%, do I need to provide ties and do the spacing limitations of 7.10.5 apply?
Ultimately, I'd like to match my tie spacing to my horizontal wall spacing. I have horizontals at 12" OC, but in a 10" wall if I have to meet 7.10.5 for my boundary ties those would need to be at 10".
This is in Seismic category B.
RE: Boundary Steel In Shear Walls
Bump. Any thoughts?
For walls not specifically detailed for high seismic ductility, I think that it's as simple as this:
If a compression load creates a demand for reinforcing in excess of 1%, you need ties meeting the column provisions. Otherwise, you don't need the ties.
I'll do a little more fact checking when I'm back at the office and have ACI handy.
Quote (CurveB)
Section 10.10.3.6 implies...
Are you sure about this section reference? My 318-08 doesn't have this clause.
Looking over this I agree that it does appear ACI 318 begins by stating that walls need to be designed for compression with ties on the longitudinal reinforcement. Then, ACI 318-08 my interpretation is section 14.3.6 overrides this previous implication that ties are always required. In the past I've considered long, lightly loaded bearing walls with in-plane bending to fall under 14.3.6 if I can ensure they have sufficient compression strength considering plain concrete only and thus do not need transverse ties.
Professional and Structural Engineer (ME, NH, MA)
American Concrete Industries
www.americanconcrete.com
Koot - my apologies: I believe I was looking at 10.3.6.2.
Thanks for the clarification CurveB. With that in mind, I stand by my original comments. While not explicitly stated in ACI, I'm confident that 10.3.6.2 is meant to apply to discrete members like beams and columns rather than walls.
Thanks KootK. Your insight is very much appreciated.
