Cell Splitting in Antennas
Hey Guys,
I still dont understand deeply about cell splitting in antennas. Does anyone have any sources that i could refer regarding this topic or explain me in detail ?
Thanks in Advance
Thanks in Advance
RE: Cell Splitting in Antennas
Dan - Owner
http://www.Hi-TecDesigns.com
Ref: from here.
From a 10,000' view (as in removing the cell tower component for a moment), the coding scheme being used will determine what type of interference to expect. For a basic example, look at multiple signals sent using the same base frequency... with a high enough auto-correlation, each signal can be easily pulled from the "noise". CDMA with a large-enough address book of Gold codes serves this purpose quite well.
The question then becomes, "What coding scheme are you using?". Of course, SNR matters heavily, too. And to your latter part, what's the antenna format? Is it a typical "cell" where multiple physical antennas are used, what form of beam-steering is involved, etc.?
Dan - Owner
