Circular Tank Control Joints
Our office has designed a 75' diameter circular concrete tank to ACI 350-06. In the mat foundation slab we have called for a circular control joint with a diameter of 32'. (8) radial control joints start at this circular joint and extend to the perimeter of the foundation. The contractor is saying it is difficult to install a waterstop on a radius. Has anyone out there run into this issue? How else would you arrange control joints in a circular slab/tank?
RE: Circular Tank Control Joints
One option would be to change from PVC waterstop to flexible hydrophilic waterstop, such as these Sika products: Link
Another option that may minimize design changes is to replace the 32' circular control joint with a 32' regular octagon control joint with any type waterstop, including PVC.
An added benefit - an octagon is easier to form accurately than a circle.
www.SlideRuleEra.net
www.VacuumTubeEra.net
That was one option the contractor suggested, but I'm hesitant to pursue it. The control joint spacing has been reduced to prevent cracking for water-tight structures. The reinforcement ratio determines the joint spacing per ACI 350-06 Table 7.12.2.1.
I don't doubt that the original engineer probably added more control joints than were necessary as an "insurance plan" against cracking.
I think increasing the reinforcement ratio would be a good solution if we were still in the design phase, but the rebar shop drawings have already come through and were approved about 2 months ago. Changing the reinforcement this late in the game would likely cause a delay and a change order.
Joints are cracks, just regular ones.
Joints are cracks, but they do have waterstops in them. Also, if you wait between pours, you can cast the next pour against a pre-shrunk section and reduce the size of the cracks.
If your reinforcing steel is at least 0.5% of the area of concrete, you don't need any control joints.
DaveAtkins
Also have seen prestress water tank slabs with thickened edges, 5" center thickness. They used post-tensioning at 5 ft. oc. to induce about 250 psi compression in slab to prevent cracks opening up.
All construction joints (reinforcing through the joint), not control joints.
