DIN ISO symbols
DIN ISO symbols
We received a drawing with some symbols that we are not familiar with. I assume that the 1, 10, and 20 values (highlighted in yellow) are a callout of sorts that will associate the dimension with an inspection report. Is this correct or do the numbers have other significance? Also, what is the meaning of the teardrop shaped callouts (35 and 66, highlighted in green)?
The drawing references various DIN ISO standards that no one here is familiar with.
RE: DIN ISO symbols
RE: DIN ISO symbols
SWsoftware indicated as for inspection.Maybe ISO TS-16949 last I heard it didn't fully document what symbol to use etc. so may come down to a company standard.
http://www.fcsuper.com/swblog/?p=3066
https://www.ptcusercommunity.com/thread/98812
thread1103-290024: Inspection Dimension (SolidWorks drawings)
thread1103-325895: Making a GD&T dimension a criticla to function dimension
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
RE: DIN ISO symbols
The drawing in the first post is from a vendor, it was not created 'in-house'.
Kenat,
Based on the supplied links, does SW = Solidworks?
FWIW, we don't use Solidworks, but our company standard is to use the oval, or 'racetrack', to denote inpsection dimensions. However, every time I've seen the oval used for inspection dimensions, it encloses the dimension to be inspected. I've never seen it as a separate callout attached to the dimension. But, since there seems to be no standard for such, I suppose it makes just as much sense as the oval around the dimension.
RE: DIN ISO symbols
RE: DIN ISO symbols
RE: DIN ISO symbols
I think this is another one of those cases where you just have to ask your customer.
RE: DIN ISO symbols
