hydro test with fresh water
Good Day to All!
sirs/ma'am,
We conducted hydro test using fresh water in tank truck and passed. but after filled with gasoline/diesel,leaks happened.
possible? causes?
Thanks in advance to all of you sir!!!
sirs/ma'am,
possible? causes?
RE: hydro test with fresh water
How long was it in the tank?
How was the tank dried after testing?
My guess is MIC.
edstainless,
thanks for your reply!!
How was the water disinfected?
no disinfection of water occur! water was come from faucet.
hydro test time duration was 1.5hrs to 2hrs.
water was drained and filled with gasoline/diesel after
thanks!
Are they the kind of people who might have sealed known leaks with silicone gunge so it would get through the hydrotest and they could get paid?
Not that any of my contractors would behave like that.
A.
sorry for the late reply..
#metengr
#zeusfaber
#chicopee
my apology for the incomplete information...all procedures(as per code/standards) and personnel were certified/qualified. Our hydro test were passed but after hydro test and gasoline/diesel filled in the tank(lorry) leaks were occured! can this be possible/happened? and can you support your answer sir?
I need some of your ideas for this failure!!
Thanks in Advance sirs!!!
r6155
What is the coating inside?
There may still be a pool of water in the bottom.
But, if it started leaking right away then the hydro was not done correctly and the leak was there before the fuel was added.
r6155
B.E.
You are judged not by what you know, but by what you can do.
http://www.eng-tips.com/threadminder.cfm?pid=1529
Use translation assistance for Engineers forum
Note the rules include No Student posting
All of this depends greatly on a) how high the hydrotest pressure was and b) where the leaks occurred. The OP needs to tell us these things for us to be of further help.
sirs,
thank you for all your responsed and given information...
yes sirs all were followed. tank was subject for annual inspection(out of service inspection).
Chris Eberly, PE
www.parkusa.com
