AutoCAD into Word document Line Weight Problem
I am trying to figure something out - I need to take an AutoCAD drawing and place it in a word document. This works fine but the problem is that I need the lines to be thicker once they are in the word doc. I know this can be done with a WMF file but I need it to remain an AutoCAD drawing. Any one out there know how to do this? Thanks!
RE: AutoCAD into Word document Line Weight Problem
I'm interested in elegant way to do that, too.
For now, I can describe my procedure:
- from AutoCAD plot into PLT file (some HP plotter should be installed as the one you plot on)
- PLT import filter in Corel allows you to specify width for colors.
Quality of the result much depends on installed plotter (you should try several).
Are there something simpler?
