CPU Time ? System time ? Wallclock ?
Can anyone tell me the diference between User, System, Total Cpu and Wallclok time ?
I want to compare the time wich my computer takes to run a job and preform results, for the same model, just differing the mesh size (seeds). What is the most appropriate time to do this ?
Thaaankss !!!
RE: CPU Time ? System time ? Wallclock ?
The .log file will tell you the dates/times your analyses began and completed. I'd just use these for your comparison.
Thank You for your answers.
How do u suggest to compare the computer effort performing the job ?
I have some models, they only differ in the mesh size. I want to acess processing time to do a reletion between results accuracy/ time spent running the job.
Thanks !!!
Those are fairly standard terms commonly used by developers. Read this.
I am not sure how granular you want to get but just so you know a truly fair comparison isn't as straightforward as you might imagine. Domain decomposition, system background load, hardware load balancing parameters, etc. are variables that end-users are blinded to.
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
Thank you for your answers !
So, what is the best way/ parameters to compare PC effort regarding to different seed sizes ?
I really want to compare the effort related to differnt seed sizes to do a relation accuracy/ processing time.
