Measure the distance of an arc (line) from point to point?
Is there a way to measure the distance of an arc in a pipe? Obviously you can't use the measure tool because it only supplies a straight line. Any other suggestions?
RE: Measure the distance of an arc (line) from point to point?
www.nxjournaling.com
