Material specification as per API 6A
Hi Friends,
i am working in valve industry related with API 6A,
i am making material specification . Clause 5.2 material specification.
For clause 5.4 body , bonnet and end & outlet connection ,
In processing ( clause 5.4.3.2 hot working practice ) . Does hot working practice make by material manufacturer or API 6A product manufacturer?
i confuse cause , in API6A , clause 5.4.3.2 hot working practice, only have written that manufacturer shall document the hot working practice.
Kamlesh
RE: Material specification as per API 6A
The "manufacturer" is the party in contract with the purchaser. Since a sub-contractor, who would be the most likely to have documented hot working practices, is generally deemed to be under the control of the manufacturer, it should simply be a case of verifying the documentation from the sub-contractor and transmitting it to the purchaser if so required.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Most cases that I know,
Manufacturer (API 6A product manufacturer) need to have specs that has to be fulfilled by sub-contractor (material manufacturer).
The specs is required to limit the end result product that manufacturer required.
During specs document creation, manufacturer might use some advice from their sub-contractor itself.
